Multicolumn Listbox slow
Recoloring cells in my multicolumn listbox is slow (1000 lines x 5-10 columns).
Yes, panel updates are already deferred. Problem is, that the users can add lines at the top of the listbox, and then every line below that has to recolor.
I will test the virtual MCLB that someone mentioned, but perhaps there is the option to change the indicator?
Is a table faster than a MCLB?
A line has only a single color, no need to color for every single cell.
Message 1 of 12
(3,968 Views)
Hi Tesla,
to increase speed you only need to color the lines visible to your user.
(I guess the user cannot see all 1000 lines at once?)
Message 2 of 12
(3,962 Views)
Thank you.
I already mentioned that I will try the virtual MCLB, but perhaps there is an easier way.
Message 3 of 12
(3,948 Views)
Hi Tesla,
I never heard of a "virtual MCLB" which "somebody mentioned".
Do you mind to provide links or example VIs?
Message 4 of 12
(3,945 Views)
Hi Tesla,
That VirtualMCLB is using the same approach of only coloring the cells visible to the user as I suggested before…
Message 6 of 12
(3,936 Views)
Yes, it is a possible solution, but perhaps there is an easier way.
That was the whole purpose of my post.
Message 7 of 12
(3,931 Views)
I was curious and tested the performance by myself. I think, this is good enough...
Greets, Dave
Message 8 of 12
(3,913 Views)
Thanks for your testing.
Just for clarifying:
My user adds a new line at the red position. Then I have to recolor every single line after that. And there are sometimes above 1000 lines.
Message 9 of 12
(3,902 Views)
Yes, after reading your first post more carefully I realized my misunderstanding. And now I see, you mean the Font-Color, not the cell (background) color. The performance of this is very poor, see my third testing- VI. I think, GerdW's suggestion is the right way- first recolor all visible lines, then all the others.
Greets, Dave
Message 10 of 12
(3,894 Views)
