Multiple DAQ devices
I have three USB DAQ's of different models. Is there a way in labview to  communicate with all three DAQ's using single DAQ assistant (one device at a time).
Thanks in advance.
(2,456 Views)
No.  If you were using PXI X-Series cards, then we can combine multiple devices into a single task.  But the USB DAQs have to have a different task for each device.
Read through the specs of the DAQs.  They may have an input you can use for the sample clock.  This would be a close compromise, but would require using the actual DAQmx API instead of the DAQ Assistant.
GCentral
(2,429 Views)
