05-23-2018 12:12 AM - edited 05-23-2018 12:19 AM
I used DAQmx with LabVIEW 2016. However, evaluation edition of LabVIEW 2018 cannot find DAGmx 18.0. I removed DAQmx driver and reinstalled but it is still not working. What is the problem?
I attached error message which appears when I open vi using NI-DAQmx.
05-23-2018 05:20 AM
You failed to install enough of LabVIEW 2018 to support your application. In particular, you failed to install DAQmx and/or the Device Drivers that you require.
05-24-2018 12:35 AM
Yeah, I reinstalled NI-DAQmx 18.0.0 from http://www.ni.com/download/ni-daqmx-18.0/7574/en/ and now the problem is solved.
I think the installer I used before did not work well...
06-03-2019 04:24 PM
I have same problem. After installation LabView 2018 and all the drivers, NI DAQmx is not seen.
I tried to install NI-DAQmx 18.6, and looks like it does not give me support for LV 2018 (see attached file).
I have LV2017 installed, it does not have such problems, I have NI DAQmx, and DAQ Assist tool there
06-03-2019 11:19 PM
Alexander_By,
If I interpret correctly your screenshot, it is showing that the NI-DAQmx installer is not finding LabVIEW 2018 installed in the system... I wonder:
All the best,
06-08-2019 03:18 PM - last edited on 06-08-2019 08:01 PM by Kristi_Martinez
Hi, Oscar
Yes, I am sure that I installed LV 2018. Installed successfully and activated (see attached capture).
And again, the NIDAQ 1860f2 does not see LV2018 as installed, see attached picture.
I uninstalled LV2018 and installed back - same results. For sure, I accepted default folders
I have LV2017 on the same computer, it works well, and no problems with the drivers
Alexander
06-08-2019 03:44 PM
It may be an "activation" problem. Open NI License Manager, and see if all of your LabVIEW 2018 components are showing as "Activated".
06-08-2019 05:18 PM
Bob,
NI License Manages shows that it is Licensed. Or I'm missing something?
06-08-2019 05:19 PM
Bob,
06-08-2019 07:08 PM
It puzzles me that the DAQmx installer does not find LabVIEW 2018 (per your screenshot)... can you try force reinstalling LabVIEW 2018 (if you have not already) and see if the DAQmx installer allows you to install support for it?
Were there any errors/warnings during the LabVIEW installation?
(If you have other machines) have you seen this behavior in other computers?
