NI FPGA Compilation error
Hi ,
I am using NI Labview version 2010 SP1 ,Xilinx 11.5 compilation tool software  and i need to compile the FPGA code for NI 7851r FPGA,While i start compiltaion i am getting the error ("Error:sim 433 Could not find the selected IP. I attached the snap here.Kindly help us to fix this.
(2,582 Views)
Hi Jaffer,
It looks like you have all the right software installed for this compilation so I dont think that is the problem. Are you compiling your own code? Could you try a blank VI or an example for the 7851r? If the examples work then please post your project zipped together so I can view what may be going wrong. If you cannot compile a blank VI then please post a MAX technical report so I can confirm that you have all the software you need installed on the system.
MAX Tech Report:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
Patrick H | National Instruments | Software Engineer
(2,528 Views)
