NI MAX VISA Alias Question...
Got an issue:
I have hooked up two USB I2C boards to a PXI rig. The two items have appeared in NI MAX with their serial numbers. I rename their VISA aliases to "I2C" and "IC2_ST".
Sometime later one of them stops working.
I replace the broken one for a new one.
NI MAX shows the new device.
I try to rename the new I2C VISA alias to "I2C", but NI MAX errors because the "I2C" is already allocated.
I cannot remove "I2C" without plugging in the old board (which is broken in this scenario). so how do I remove the "I2C" alias without plug in the board?
I am await of the "Reset Configuration Data", but this will reset all the aliases. There must be a better way?
NI MAX version 5.3.1
Thanks.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(3,340 Views)
Accepted by topic author ChristopherPovey
ChristopherPovey a écrit :
Got an issue:
Thanks.
I have MAX 14.5 so it might be a little different.
In MAX:
Tools -> NI-VISA -> VISA Options
In general settings select Aliases
Select the Alias you want to clear
right click -> Clear Alias
You can then give this alias to the new board.
Ben64
(3,278 Views)
Excellent.
Thanks.
Christopher Povey
(3,269 Views)
