04-03-2018 09:40 AM
Hi!
I'm trying to develop drivers in LabVIEW for an USB instrument. My problem is that on NI max, I do not see the instrument. In Windows devices (windows 7 - 64 bit), it is recognized as: USBIO controlled devices - USBIO Device: VID = 03EB PID = 2FFB, and with its software installed on the PC works correctly. How can I solve?
Thank you
Solved! Go to Solution.
04-03-2018 02:07 PM - edited 04-03-2018 02:10 PM
These are some results after searching for "ni max usb devices" using Google. They should point you in the right direction.
http://www.ni.com/getting-started/set-up-hardware/instrument-control/usb-connect
http://www.ni.com/tutorial/4478/en/
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KvOSAU
04-04-2018 10:06 AM - edited 04-04-2018 10:08 AM
