Thanks for your reply! It seems to have worked a treat!
I did the following steps:
1. uninstalled VISA 4.0 and DAQmx 8.x
2. installed DAQmx 8.6 (i wanted to upgrade to this a some point anyway)
3. installed VISA 4.2
I can now open the Installer Properties => Additional Installers window and have the following options:
and now that i can select the Measurement and Automation Explorer it has solved a second issue for me that i posted on this forum (see:
Problems with building and installer - hardware config). An error used to occur when i tried to include the "Hardware Configuration from MAX" but there are no errors now. Im sure it has something to do with also including the MAX in your installer. See Below:
Happy days for a monday
Message Edited by ali66b on
11-19-2007 11:21 AM
:. LV2010 SP1 ... W7 .:
