09-16-2010 02:53 AM
In short - how do you install NI Web-Based Monitoring and Configuration on a PC?
I built a stand-alone web service installer (NI LV Web Services Runtime and all of NI LabVIEW Run-Time Engine 2010 included) and installed it on a clean PC. The web service works fine (after this little problem was overcome), however I was expecting to be able to configure the Web application server from the web page http://localhost:3580, but there is no such page available.
Does not the above mentioned additional installers include the "NI Web-Based Monitoring and Configuration" tools? I would expect them to...(one for the Idea Exchange...) but if they do not, which installer does (or are we supposed to edit the configurations manually)?
09-16-2010 10:07 AM - edited 09-16-2010 10:07 AM
MTO,
The web based configuration software uses silverlight 3.0. Make sure this is installed.
You are not trying to view this page for a RT target correct? Because if this is the case you might have to go to MAX and configure some items dealing with the web service.
09-16-2010 10:15 AM
So it should have been there?
The machine is running Silverlight 4 (4.0.50826.0) so I assume that's not the problem as it works fine on another machine I have (which has a full LabVIEW Developer Suite installed though, not just the Run-Time Engines...).
It's not on RT no - but it's on a Windows 2008 Server...so there is probably no official support for it...(?). I have not tried it on a clean Windows 7 or Vista machine yet though as I wanted to get it running on this particular server (and as I mentioned, the web service itself runs fine).
09-16-2010 11:16 AM - edited 09-16-2010 11:17 AM
The quick answer is im not sure if it should be there. I do know that the following are required to run the web based configuration page.
I know for sure that an instalation of labview installs the formentioned products. Im trying to figure out how we can get these installed on a server target from a machine with labview or via installers as you have tried.
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
[Created 09/16/2010 11:15:15]
09-21-2010 09:03 AM
Any progress on this? Does anyone at NI know what installer is needed to get the web based configuration interface?
09-23-2010 11:45 AM
NI LabVIEW R&D is currently looking into this, and we will post here as soon as we have have more information.
09-23-2010 01:58 PM
Mads,
It is apparent to me now that we didn't include the web configuration pages as a part in the "Additional Installers" from the installer builder. This was an oversight that I will look into getting corrected ASAP. In the meantime, it would seem you have a few options:
I hope this helps.
