NI cDAQ 9178
Hello everyone
I have question regarding using of cDAQ 9178 using LabVIEW 2024, I always use NI 9174 but I have an old one and I want to use it in application. I am not sure if it will work or not. thank you.
(135 Views)
cDAQ is dependent on DAQmx driver support. So, as long as there is common DAQmx version that supports 9178 and LV24, you are good to go.
So, DAQmx 23Q4 and 24Q1 support LV2024.
9178 is supported by 22Q3 and above
So, essentially, installing the DAQmx 2024Q1 with LV2024 will work with 9178
Santhosh
Soliton Technologies
(118 Views)
Sorry, I asked my question wrongly. I have cDAQ 9172. Can I still use it with the new versions of LabVIEW? cDAQ.jpg
(92 Views)
Unfortunately, 9172 is just too old to work with any latest software and it was last supported by DAQmx 17.5 driver
And DAQmx 17.5 is compatible with LV 2014 - 2017
Santhosh
(79 Views)
Thank you Santo. I have LabVIEW development license working on LabVIEW 2024, can I use the same license form old LabVIEW version like 2014, so I would be able to use my 9172.
(65 Views)
