NXG 2.0 installation error
Hi everyone,
I'm trying to Install NXG 2.0 using the package manager and get an "invalid checksum..." error (attached).
Any similar experiences or proposed solutions?
Thank you
(3,457 Views)
Accepted by THERMAN
I would suggest you to check this post (https://forums.ni.com/t5/LabVIEW/LabVIEW-NXG-1-0-installation-error-quot-Check-Internet/td-p/3635121) where i think an error similar to what you are getting has been solved 🙂
It was with version 1.0 but you might aswell try it out with files for 2.0
(3,436 Views)
Have you updated to NI Package Manager 17.5? If not you should try updating that first and then try installing LabVIEW NXG.
Brandon Grey
Certified LabVIEW Architect
(3,408 Views)
Thanks, it wasn't exactly the same issue, but I did find the answer there - it was a problem with the local network I was connected to.
(3,377 Views)
The issues that were being seen were actually a result of an internal error on our end. We pushed a fix late Thursday night that most likely resulted in the error going away.
Brandon Grey
(3,357 Views)
