Naming results file programmatically
    I'm working on a test setup where the user enters data about the UUT they're about to test. Stuff like model number, serial number, tester name, and whether the test is an initial test or final test. I'd like all this data to automatically be used to create the output file name.
Something like: S16-10_SN1234_Mike_Initial Test
What's the easiest way to do this?
Jay
(1,797 Views)
Use Format Into String to build a file name with all of your parameters.  You can then use Build Path to add that file name to the destination folder path to create a full path for the file.
GCentral
(1,789 Views)
Hi Jay,
use FormatIntoString...
(1,786 Views)
So I've currently got the user's responses formatted into a string, but how do I add in underscores in the right places?
Jay
(1,783 Views)
Accepted by JayWW
Here's the actual code I use to generate a report file for you to use as an example.  As far as adding underscores, just put them into your format string.
GCentral
(1,777 Views)
