Need a Ni 9401 or no
Hi all,
I have a cRio 9047 and I want to connect a rotary encoder with 5000 point per revolution.
Do I need the ni 9401 or the internal timer of cRio 9047 should work ?
Thank you !
Best;
Yasmine
(965 Views)
cRIO-9047 has four counters that can do the encoder measurement via the counter task. You would need digital input channels to route the external encoder signal to the counter. You can choose any C Series Digital Module that suits your requirement in term of logic level and channel counts.
(940 Views)
Thank you for your response. Can you please propose a reference for the module C to choose and how to wire it to the cRio and the sensor.
Thank you.
Yasmine
(881 Views)
