Need a Ruska 6200 manual...
Hey all, I am doing a project using an old Ruska 6200. It would be very helpful if I had a manual for the thing, but the company (now GE) disavows any knowledge of the box and I can't find one any where online. If someone has a manual for this beast I would be eternally grateful if someone could photocopy the pages related to the serial interface for me...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 1 of 11
(5,917 Views)
Hey Mike,
I've sent inquiries to other people to find the manual for you but in the meantime I found this document that may help you at least initiate communication with the Ruska 6200.
Located here, this document says it (or a similar model) communicates through RS232 (ASCII), no handshake, four selectable baud rates (1200-19200 baud), outputs a string in this format 955.38<CR><LF> ("955.38" (in hPa), and goes on to discuss more features of the device.  I hope this helps.  I'll let you know if I'm able to locate the actual manual.
David Pratt
Group Manager for Application Engineering Specialists | Automated Test
NIC
Message 2 of 11
(5,888 Views)
Thanks for the reply, I found the same document and from the sound of it, the device can be set to periodically spit out the current pressure reading, but I was wanting to verify that is the case since I also don't have access to the device itself right now...
Mike...
LabVIEW Champion
Message 3 of 11
(5,871 Views)
Hey Mike,
Unfortunately without the manual, it would be difficult to know that for certain unless an individual from our community here knows particular feature of your Ruska device from experience.  I'm still awaiting response from my inquiries and expect it to take longer than usual due to the holiday season, but as mentioned before will let you know as soon as I hear anything about it.
David Pratt
NIC
Message 4 of 11
(5,828 Views)
Mike:
bmwjoe may have answered your prayers today, see here:
http://forums.ni.com/ni/board/message?board.id=140&thread.id=22918
Have not looked at it, but hopefullt it has the goodies you need.
-AK2DM
Message 5 of 11
(5,815 Views)
Accepted by mikeporter
Hey Mike,
That link works but loads really slow for me.  I've attached a saved version of the file for you.
David Pratt
NIC
Message 6 of 11
(5,811 Views)
Blessings on both of you! This is exactly what I was needing!
Mike...
LabVIEW Champion
Message 7 of 11
(5,769 Views)
Looking for RUSKA model 6222-19-19 calibration manual. Is anybody know where I can find it?
Miguel
Message 8 of 11
(4,715 Views)
Miguel
You should probably make your own thread (and reference this one if you want to), since this is a 5 year old thread that has been marked as "solved."
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(4,711 Views)
Thanks!!!
Message 10 of 11
(4,701 Views)
