Need help with combination-code assigment
Hi forum!
I have a school-assigment to next week and Im struggeling with the idea on how to make a 4 digit code-lock with a possebility to change the code with a master code.
Im using a hardware keypad with 10 digits (0-9).
Can anybody please help me with this?
Apologyse for my English Smiley Tongue
Message 1 of 8
(3,216 Views)
Think about all the steps involved in what you want to do.
You need 4 inputs, 1 for each digit
You could use a button to check if the code is correct
Something that says if the code is good or bad
A button to change the code
Start with that and see how far you get.  Then think about how you can program it.  Start programming.  When/if you get stuck post your code and explain the problem you are having.
Message 2 of 8
(3,211 Views)
The first issue is getting your keypad values.  That will likely be done with a digital port.  But you will want a VI that does nothing but read the keypad.
From there, I'm picturing having a loop that just reads the keypad and adds the read digit (when there is one) to a string.  After 4 numbers, check the keypad and react accordingly.
GCentral
Message 3 of 8
(3,182 Views)
Guess I just blew right past the hardware.....
Message 4 of 8
(3,179 Views)
Do you have any code written at all? Its easier to steer a moving car.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 8
(3,159 Views)
So here is what I got so far.
Just found out that I dont have to set the mastercode on hardware side, but I can use software to set the mastercode.
Need to be pointed in the right direction, any suggestions or tweaks you guys can point me in?
Message 6 of 8
(3,112 Views)
How do you know when you can read the port digital IO?  Where is the loop?  You will need a shift register to keep the previous numbers in and then compare that to the combination once enough numbers have been entered.
I don't have the myRIO stuff installed right now, but you should be able to just read the A port in its entirety as a number.  That would make things a lot cleaner and simpler for you.
GCentral
Message 7 of 8
(3,087 Views)
So, I've made this out of the assignment. But I need a sequense of the numbers so I dont need to push everything in at once. And tips or modification you peaople can help me achive this?
Best regards
Message 8 of 8
(3,041 Views)
