Need to pass arguments to subvi that runs in parallel to main vi.
Please help me.
I can successfully pass arguments to a sub-vi using "call-by-reference-node" but the sub-vi will not run in parallel.  I can also run my sub-vi in parallel by using "invoke node", but then cannot pass arguments.  I can't seem to figure out how to merge these two concepts together.
When I open the VI reference, I have to specify the strict type, when using call-by-reference-node.  When I use invoke node, I don't specify the type.  It seems that specifying the strict type keeps the VIs from running in parallel, but also seems necessary to pass arguments.
I apologize for my lack of a deeper understanding of this and appreciate any help you can give me.
Chris
(2,766 Views)
Accepted by ctojeira
You need the invoke node "Ctrl Val.Set".
(2,740 Views)
Is your vi reentrant? Also each call by reference needs it's own static vi reference constant. (I think)
LabVIEW 2012
(2,731 Views)
The code in this Nugget may help get you started.
Preview...
It launches multiple FPs to simulate each notes from an Aimusic video.
Ben
(2,716 Views)
FANTASTIC, Jean-Marc!!!!!
Thank you for your great insight!!!!
Chris
(2,696 Views)
