Netscanner 9116+LabVIEW
I'm new in this forum.
I would like to say hello to all.
In this time I'm  working on engineering thesis.
I'm from Poland but this semester I'm studing in Germany.
My topic of Bachelor Thesis is measurment pressure,temperature,flow in gas turbine.
I'm working with LabVIEW 2009 and with NetScanner Model 9116 (isn't to much information about this in Network).I've no idea how can I connect this measurment pressure in LabVIEW with Netscanner 9116?I've a connection with ethernet between
my computer and Netscanner via  Esterline Model 9IFC.
Excuse me for a mistakes.
Kind regards,Tom
Message 1 of 15
(6,875 Views)
Accepted by Wuja
Tom,
Actually, thanks to Pressure Systems doing the leg work, controlling and reading data from Netscanners into LabVIEW is very easy.  First, download the LabVIEW drivers from their website:
http://www.pressuresystems.com/Portals/11/SoftwareFirmware/NetScanner/netlab.zip
Once you've extracted the .exe, run it and save the files to a directory you can access easily.  Then extract the PSI9016.llb from the file 'newlvvis.zip'.
Then you can write a very simple application to initialize, rezero, and read from the modules, much the same as you would do buffered acquisition with NI DAQ boards.  One thing I've learned from using these VIs over the years - don't directly wire the TCP address out from the initialize routine directly in to the subsequent VIs.  Instead, create an indicator of the address, then use Local Variables reads to send the address into the Rezero, Read, and Close VIs.  Finally, the Rezero routine assumes that you have a 100-120 PSIg dry gas (air or nitrogen) connected to the 'SUPPLY' port on the Netscanner.  This allows a pressure-activated solenoid to actuate which puts equal pressure on both sides of the diaphragms of all the transducers.  Skipping this step can lead to offset data!
Good Luck,
Jim
Message 2 of 15
(6,861 Views)
thanks for your kindly reply.
I've already these drivers.
I'm starting with work:)
Have a nice weekend.
Kind regards,Tom
Message 3 of 15
(6,848 Views)
Can you please send vi file how to use this source library function like NI DAQassistant
thanks for advance
Message 4 of 15
(6,658 Views)
Can you please example vi file how to use this Netscanner 9116 labview vi files similar like NI DAQassistant
Message 5 of 15
(6,656 Views)
Hi Mic,
as PressureSystems isn't related to NI you will get no support for their products directly through DAQAssistent (or MAX or DAQmx or...).
You have to use the library of functions as supplied by PS by calling them as simple subVIs! And read the (context) help for those functions...
Message 6 of 15
(6,647 Views)
here you've simply application for a Pressure Systems devices.
Kind regards,Tom
Message 7 of 15
(6,624 Views)
Thank you
But we are having Labview 7.1 can you please send me for LV 7.1 compatible
Thanks in advance
Message 8 of 15
(6,612 Views)
here you've for 8.0
Kind regards,Tom
Message 9 of 15
(6,607 Views)
Hi Tom,
 I am very sorry to ask again I dont have Lab view 8.0 also, If you can make it  in Labview 7.1 compatible will be great help to me further
Thanks in  advance
Message 10 of 15
(6,598 Views)
