Network Stream not working in executable compared to VI
I may repeating the same question, appologies if it so and guide me through the relevant post for solution.
1. My application is working fine with LabVIEW using Network streams for Host and RT
2. After converting to executables, I am not getting any data.
3. If I run the RT using LabVIEW and host with executable I am getting the data.
I cheked the URL name in writer and reader endpoint which is matching. Attched the Ntework stream VIs below for RT and Host.
Any help will be appreciated.
(640 Views)
It is difficult to understand communication between Host and Target in a LabVIEW RT Project without having the Project File and the sub-VIs that describe the establishment of the Network Streams.  I recommend you compress the Project to a .zip file and include the entire Project.
(580 Views)
Thanks Bob for the support,
Actually it was not issue with Network Streams. After troubleshooting came to know that, it was the FGV which was causing the problem. I have used property node in FGV which was not working in executable file and working in VI. After updating the FGV, it cleared the issue and was able to read the data from RT to Host.
I am posting here, hope it helps someone.
Rajashekar SK
(546 Views)
