Neural network in LabVIEW - I'd like to share the code
Hi Everyone,
I have developed a fully configurable multi-layer perceptron (artificial neural network), feed-forward, back propagated. I used LabVIEW 5.1 and wrote the whole thing from scratch. The program (aNETka ver. 1.0) incorporates: biases, autoscaling, automatic learn rate, momentum, etc.
You can download the zipped file from: http://www.geocities.com/zureks//aNETka.html
UPDATE: The website will soon go off-line because Yahoo shuts down the geocities. You can email me directly then: zureks@gmail.com
There is a operating manual, too Smiley Happy
Please post some comments if you use it...
Enjoy
Yodo
Everything should be made as simple
as possible - but not simpler.
Albert Einstein
Message 1 of 25
(12,779 Views)
Hi Yodo
Basically it looks quiet good. The only thing I really get annoyed of is the huge diagram. Did you use a beamer with resolution 16000 x 12000? It's quiet hard to see how it works.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 25
(12,759 Views)
oops, guess there was a lot of interest in your program, you have exceeded you transfer allocation! And on a "non-Naughty" site!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 25
(12,756 Views)
The resolution I used was 1024x768. I know the diagram is huge, but I found that using subVI's slows down the algorithm a lot (in fact, the first version was one screen diagram with neat subVI icons). I took me a lot of time to rebuild it into non-subVI version, and since I did I just kept this mode. The most important bit is the main While loop - i tried to put the smaller pieces into Sequence or Case structures to be able to see what's going on. If you really want to see how it works just make a subVI's from the structures I provided, and then you can scale the whole diagram down.
I also submitted this example code to NI, but I can't see it (search engine doesnt find it). Just be patient with the free website I provided. Should work every 1h or so Smiley Wink
Yodo
Albert Einstein
Message 4 of 25
(12,749 Views)
Thanks for sharing your work. Again something I tried to develop some years ago, but I never passed the original Perceptron level (single layer network). That thing was already smart enough to recognize numbers. 🙂
I'll try to run your vi on a few data (that could be the E-List...) as soon as possible.
That's worth 5 stars !..
Chilly Charly    (aka CC)
Message 5 of 25
(12,730 Views)
Thanks for the words of appreciation. It was really hard thing to do. I got lost with the first version and I had to start completely from scratch again, because there was no way I could debug it.
I am sorry for not very "clean" coding, but for me it was enough and too much to get it working...
Yodo
Albert Einstein
Message 6 of 25
(12,724 Views)
Thanks!
I will look at the code later.
JLV
Message 7 of 25
(12,716 Views)
Dear all,
I have visited the pointed URL, however no download option was available. So, I sent a message to the indicated e-mail, but I have not receive an answer yet (it is about a week now). Do you know if there is an alternative URL or  e-mail adrress, or any other communication way to ask for a copy of the toolkit. Do you know any other LabVIEW implemented neural network training tools that someone could try or even buy.
Thanks!!!
Message 8 of 25
(12,624 Views)
Message 9 of 25
(10,870 Views)
NI has a community section now which makes it easier to post documents and files. You could place it there.
___________________
Try to take over the world!
Message 10 of 25
(10,844 Views)
