Newbie Question - Streaming HTTP POST to a server
Hello
I have searched, and am continuing to do so, and may well have already found the answer an not realised yet. But, if someone better placed could help me I would be very grateful.
I am trying to "learn" labview, and am tinkering with something written by someone else that needs modifcation.
A quick background:
We are reading strain gauges, and writing to a CSV file. In order to write, the program must be stopped, the file written, then restarted.
We need it to stream live data to a server.
I *think* I have modified it correctly to at least write "live" to a CVS rather than needing to be stopped and started, but I also need it to stream live to a server too.
I have attached a snipped of the part of the circuit I need to modify. As I said, I think I have this correct for appending a CSV "live".
How would I take the data and stream in the form of a serial string straight to, for example, here:
http://posttestserver.com/
I'm looking at examples of other bits in the tutorial etc but they look a little over complicated.
I appreciate I am likely asking a very basic question, and will likely get slapped with a very obvious pre-existing design, but at the moment I simply don't understand Labview well enough to realise what I am looking at half the time! So apologies for that.
Many thanks
Dave
(2,809 Views)
Accepted by Fall-Apart-Dave
Hi Dave,
I recommend you check out the getting started examples provided with LabVIEW! They show some very clean code for many applications, including pushing data to a server.
LabVIEW example finder: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIKbCAO&l=en-US
When you open up the Browse tab, you should see many folders. I'd recommend checking out the fundamentals to learn more about using LabVIEW in general. For your particular problem, I would look into the Networking folder, specifically the TCP&UDP folder.
Alternatively, you could use the HTTP VIs to post data to the server.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
http://forums.ni.com/t5/Community-Documents/Easy-HTTP-Client-VIs/ta-p/3536071
(2,742 Views)
Thank you!
(2,658 Views)
