06-25-2013 10:35 AM
I am moving an application from one computer to a new one. Lease ran out. I get the following mesaage when I try to load my tasks and scales using the Export Device Configurator.
Ni-DAqmx8.7-50204
the specified file could not be opened. The operation could not be completed as specified. I have attached the file and messages below.
What am I doing wrong?
06-26-2013 11:15 AM
Hi SILVER,
Could you attach the screenshot of the error? Also, which OS and LabVIEW version you are using?
Carmen C.
07-01-2013 08:47 AM
Running Labview 8.5.1
07-02-2013 11:02 AM
Hi Silver,
Which OS you are using? Windows XP, Windows 7? 32bits or 64 bits? We would like to check the compatibility of LabVIEW, drivers and OS.
Esteban R.
09-10-2013 10:23 AM
I was upgraded to windows 7 and have a 32 bit system. It is not seeing the Compact DaQ for some reason.
Regards ,Silver
09-10-2013 10:31 AM
Hi Carmen,
I am using Windows 7 and a 32 bit Dell. I receive the same error 50204 when I try to create a scale for the Compact DaQ. For some reason maybe compatability or maybe something else (missing software or settings I am not seeing the Compact DaQ as a device in MAX.
Regards, Silver
