Null padded string
I need to create a string padded if with 0x00 if length is not met.
sample
lenght = 30
input = 123456
should look like this in hex
0x 3132 3334 3536 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
or in "/" display
123456\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00
tried "format into string"  It either won't work for padding with 0x00 or I'm not formatting it correctly
(3,765 Views)
in 1000 words equivalent
"Should be" isn't "Is" -Jay
(3,762 Views)
Why not start with a null padded string (init a u8 array to size 30 and convert to string) then replace the front of the string with replace string subset.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,760 Views)
Good Idea Paul!Smiley Very Happy
(3,741 Views)
Accepted by RRRRSSSS
Very good idea.  Except, I would just use Replace Substring instread of converting to a byte array and back again.
GCentral
(3,724 Views)
One more suggestion (which I think is simpler than the above proposals): convert to a byte array, reshape the array, convert back to string. String to Byte Array, and vice versa, are free operations - they do not allocate memory buffers or make data copies.
EDIT: before someone points this out, yes, this only pads with nulls. If you need to pad with some other character, use on of the other suggestions.
(3,688 Views)
