Obtain Current VI's Menubar
Anyone know how to obtain a reference to the Real-Time Menu without using Current VI's Menubar and Event Structure? Is it possible to obtain the reference of the Real-Time Menu from VI Server Reference and Property Node? Thank.
Message 1 of 11
(4,689 Views)
The only menu-bar properties that are accessible through the VI server are "Front Panel Window: Show Menu Bar" and "Run-Time Menu Path".
Why do you need to access through the VI server? You should pass the menu bar reference through to wherever you need it. If you have the Vi reference there already, then you should pass the menu reference the same way.
I usually structure my class data for my user interface to include a VI reference and menu bar reference. That reference gets set when the interface loads and is then accessible in my data cluster elsewhere.
Cheers
Message 2 of 11
(4,682 Views)
Why do you need the Front Panel Menu bar for a VI running on an operating system that doesn't use Front Panels?  Perhaps you're going about something the wrong way.
Jim
Message 3 of 11
(4,672 Views)
Oops, good point. I read it as "run-time", so maybe that's what OP meant.
Cheers
Message 4 of 11
(4,667 Views)
I wanted to obtain the reference in any other way, because I use the "Open VI Reference" and not pass the reference to the subVI. I simply wanted to know if there was any alternative to obtain the reference from the Real-Time menu. Thank.
Message 5 of 11
(4,650 Views)
Nope. And you keep saying "real-time", but you mean "run-time", right?
Seems like something that should be possible though. Maybe submit a post to the LabVIEW Idea Exchange
Cheers
Message 6 of 11
(4,644 Views)
Sorry, Is Run-Time menu. Thank.
Message 7 of 11
(4,634 Views)
I'm looking for the answer as well.  For regression testing (and I'm stuck on LabVIEW 7.1 due to progam baseline), I need to be able to remotely select a menu option.  So I need to find the MenuBar reference programatically.
Message 8 of 11
(4,381 Views)
Well there is a private method on the VI for Invoke Built In Menu Item, but it also says Not Implemented in 2015, not sure if it actually works or not.  I also suggest Idea Exchange.
Message 9 of 11
(4,369 Views)
Hi Dina,
when there is a run-time menu you should have a state machine or a queued message handler to process the menu selections of the user.
If this is the case and you still want to "remotely" select a menu option all you need to do is put another mesaage in your message handler (or call for  a certain state).
With the right VI architecture it is simple to include remote control options…
Message 10 of 11
(4,357 Views)
