Opening VIs in run-time with LV8.6
Hi Forum
Is there a way to force a VI to open in run-time mode in LV8.6? With LV 7.1 I could right click the VI and select either developer  or run-time, I don't seem to have that feature with 8.6.
B.R.
Martin
(2,495 Views)
Do you mean the "Run when opened" option?
If so, it is there in the VI Properties >> Category - Window Appearance >> Customize...
- Partha ( CLD until Oct 2027 🙂 )
(2,491 Views)
Maybe Lentz is referring to FP.Open and FP.close property
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(2,482 Views)
Not realy, with that feature, it is still the Developer Engine that is running the VI. Not the Run-time engine. Or at least the VI behaves differently.
My reason for asking is that I see different behaviour when I use "run-time" and "development" adapters in TestStand and would like to investigate the errors outside my TestStand environment.
/Martin
(2,477 Views)
