Opening a VI from another VI.
I'm currently writing a program which shares data between 2 VI's.  I need a button on one of them which opens the other is there a way that this can be done???
Matt.
Message 1 of 12
(3,440 Views)
Hi Matt,
Have you tried to create a sub-vi? That will work, if you have 1 main VI, that will need to call some other functions that are implemented in other VIs.
Is that you case?
TN
Currently using LV 8.5
logo
Message 2 of 12
(3,436 Views)
Ok I will give that a try have you got any examples I could have a look at?
Matt
Message 3 of 12
(3,431 Views)
Hi, I don't really know what you want, but you can place SubVI into MainVI and let work them parallely. If you only want to show the Front Panel of the SubVI, than you can use the VI Server to do it. It would be the common statical call.
If you want to make something like a menue and START your SubVI dynamically, than take a look on this example:
http://labviewportal.eu/en/front-panel/83-interactive-menue
Message 4 of 12
(3,422 Views)
Have a look at what i attatched. Hope it help. 😃
TN
logo
Message 5 of 12
(3,418 Views)
Sorry but I'm using Labview 8 not 8.5 do you have those programs in an older format??
Matt.
Message 6 of 12
(3,408 Views)
Sure, here it goes.
TN
logo
Message 7 of 12
(3,404 Views)
Forgot to attatch..
TN
logo
Message 8 of 12
(3,399 Views)
Thanks for the help.
Matt.
Message 9 of 12
(3,394 Views)
Accepted by gilgad2000
Did that solve your problem?
If yes, don't forget to mark the solution and to give kudos! 😛
TN
logo
Message 10 of 12
(3,389 Views)
