PDF reporting
Hello everyone. I have a small question related to the creation of pdf report files.
Basically I used the recommendation from this link: https://forums.ni.com/t5/Example-Programs/Save-Word-or-Excel-report-as-a-PDF-using-Report-Generation...
and it works fine with creating pdf. The only problem is that, "Append Front Panel image to Report.vi" pops-up a doc file first. Is it possible to make it perform silently?
Namely, doc file created in the background and printed to pdf and deleted afterwards?
Any other solution to this is welcome. Minimal working example is attached, both as an image and LabView file.
Thank you in advance.
(3,685 Views)
Seems to work fine for me...
I don't get any doc pop-up. I do get a pdf.
I do get a red cross across those reporting VIs, and when I open them, there's a message saying the VIs are deprecated:
This VI is deprecated. Use the following VI instead:
vi.lib\Utility\NIReport.llb\Create Report.vi
But that could be because I'm using LV18, not LV17.
(3,444 Views)
Accepted by alljustforfun11
Oops, there are actually word documents opened!
They don't pop-up, so I didn't notice.
It's not related to the PDF generation, the Create Report.vi opens an instance of Word by default.
Set the "window state" input (of Create Report.vi) to "no change". That works for me.
(3,437 Views)
Amazing! Works for me as well. Thank you a lot for your help 🙂
(3,180 Views)
Hi alljustforfun11,
There is a simpler method to create a pdf file from a word document in LabVIEW that they failed to post in "https://forums.ni.com/t5/Example-Programs/Save-Word-or-Excel-report-as-a-PDF-using-Report-Generation...
Give direct pdf prefix path to the vi  "C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\Utility\NIReport.llb\Word\Save Report to File.vi"
It is handled to save the pdf as shown below
Muthu Karthik.M
(2,373 Views)
Why is that simpler?
In stead of a method with clear inputs, you get a method with variants that need magic numbers to be wired.
It's good to have alternatives of course...
(2,346 Views)
