PF3000 or PF4000 (atlas copco) Open Protocol
Hi all!!
Please help me!! the PF4000 or PF3000 have Open Protocol ethernet, I try connect LabVIEW Between PF3000 or PF4000, but I Can´t.
I have the Data that I need send MID 0001 to get communication with device, but the Device not respont, I write like this "MID 0001" , the manual said " The Integrator Send MID 0001 Communication start and the Controller answer MID 0002 Communication start acknowledge" but the controller not respons.
I need add something? to message or What I need doing?
I attached the file where description the OPEN PROTOCOL.
Please help me!!! Smiley Surprised  I will crasy.
If you have some examples, please send me one
Thanks for all
Best regards
Message 1 of 10
(13,668 Views)
Hello qz6y7q,
Thanks for using the National Instruments Discussion Forums, can you share with us your VI to see how are you trying to communicate?
Have you tried to do a ping to the protocol server?
Best regards.
David P.
Applications Engineer
www.ni.com/soporte
Message 2 of 10
(13,613 Views)
Hello!
I happen to have an implemented VIs for Open Protocol for Desoutter CVIR2 - but as far as I know, OP is completely universal in terms of device, so you won't probably need any modifications.
Please PM me for the code.
Message 3 of 10
(13,384 Views)
sir can u send me the sample vi .how to read and send commands to the controller
EMAILID :hvijaycbe@gmail.com
Message 4 of 10
(12,517 Views)
sir can u send me the sample vi.how to read and write commands to the controller
emailid:hvijaycbe@gmail.com
Message 5 of 10
(12,515 Views)
Could you just ping me the code for extracting the data from the power focus controller using this open protocol ?
Message 6 of 10
(11,755 Views)
Could I just have your code for extracting information through this open protocol ?
Message 7 of 10
(11,752 Views)
Sorry I realize this is an old thread but do you still have this code that you could share?
Message 8 of 10
(9,088 Views)
Hi please can i get the labview codefor open protocol aswell. Id really appreciate it
Message 9 of 10
(8,645 Views)
Sorry I was never able to get this code. We ended up using ToolNet8 a database software from Atlas and pulling the data out of a SQL database. If you come across this code let me know.
Message 10 of 10
(8,639 Views)
