PID controller with generated data as input
Hello Marian,
Here i have attached the Vi that i have made recently.
Before implementing the actual PID controller simulation using my sensor data now i am trying to design the simulation just by using a sine wave generator inside the system (as expressed in general PID simulation.vi) .
Again i cant make it out . I hope you can help me .
Thank you.
Bala
Message 11 of 15
(933 Views)
Hello Marian,
Thank you.
Bala
Message 12 of 15
(933 Views)
Hello Bala,
I will attach a screenshot of my modified VI since it would take a while to go to our testlab and convert the VI back to LabVIEW 7.0.
I think you will be able to easily follow the changes that I made in order to see a signal that can be controlled by the PID setup.
Please try this approach and let me know if it worked.
David
Message 13 of 15
(918 Views)
Hello David ,
I executed the vi that you have sent me . But in that when i change the propotional gain to any value higher than 1 then the system is not controlled.And also i dont understand the logic that you have not given the output from PID controller to the system.
I am attaching the same vi with some extra indicators for a good view.
thank you,
Bala
Message 14 of 15
(912 Views)
Hello Bala,
let's solve your inquiry. I have not got the point yet: what are you trying to archieve? On one hand, you have a set of datapoints from your sensor. On the other hand, you like to implement a PID. I do not understand the connection of both. Do you want to exermine the reaction of the PID-Controller when you connect static values from your sensor on the input? Could you draw a little scetch of your control-loop?
Best regards
Marian Vorderer
Message 15 of 15
(883 Views)
