PXIe 4139 signal randomly becomes very noisy
I am trying to measure the current of a photosensitive device using a PXIe 4139. The current is in the order of a few nA. When I turn on a light, the current increases and I need to record the trend of the current. I'm having difficulty in setting up the SMU to get a clean signal. It only works sometimes, for some reason the signal switches between clean and super noisy randomly, without interfering in the measurement at all.
Here is an example. After 6 seconds, the noise starts. I didn't change anything in the setup/software.
Here the signal starts noisy and suddenly became clean.
Using instrument studio, I don't see any noise.
Here is the code of the above examples:
What could be the problem here?
(454 Views)
To be clear, this happens only with your DUT (photosensitive device)?
InstrumentStudio settings are not the same as your code.
A few best practices,
  1. Disable measurement auto range
  2. Choose the smallest current range that works
  3. Try Local vs Remote sensing
  4. Set aperture time to #N PLC instead of seconds to ensure you eliminate power line noise
Santhosh
Soliton Technologies
(434 Views)
