Pass Variables through Case
Hello! I am trying to write a VI to control hardware through GPIB communication. The communication is going well. However, I would like to change which vi controls are enabled for the user based on which "mode" the user selects. This mode is 1 of 3, and it would be determined by the user clicking a boolean switch. My plan is for the switch to be a single LED control, and when one of the three is on, the other two are off. If a new LED is clicked, it will light up and the others will go off. I am having difficulty making this. I was planning on using a case structure, but I cannot figure out how to determine which is selected and have this effect, because I cannot edit the values of each control in every case in the structure. I thought about using local variables and passing them through the case structure, but I cannot seem to get this to work either. I appreciate any help in solving this. Thank you in advance!
(2,357 Views)
Accepted by jfherrm
You can simply use the radio button control.
(2,354 Views)
This sounds like a job for Radio Buttons instead of three separate booleans.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,349 Views)
Use a radio button and if you want to use 3 buttons then build an array and give the output to a search 1d array and then connect the output to a case structure.
(2,340 Views)
