04-18-2024 04:12 PM
I'd like to use Python to read the value of a string indicator in a LabVIEW executable. I created a proof-of-concept exe that generates a string, and following this LabVIEW support doc I can successfully read the string value in python using the following script:
import win32com.client
LabVIEW = win32com.client.Dispatch("Application.Application")
VI = LabVIEW.getvireference(r'C:\temp\ActiveXpractice\My Application\Application.exe\ActiveXpractice.vi')
while True:
result = VI.getcontrolvalue('String')
print(result)
The problem is that when I try this with another LabVIEW exe that was made from a larger LabVIEW project including many subVIs, I get the following error:
com_error: (-2147352567, 'Exception occurred.', (6945, 'LabVIEW', 'LabVIEW: Open VI Reference no longer matches VIs in memory by filename. A filename is no longer sufficient because the full name of a VI now includes any owning libraries.', None, 0, 0), None)
The only difference between the two executables that I can tell is that the first one was built from a project with a single vi, while the second contained many subvis other than the main one being referenced. Does anyone understand what this error means in this context? Is there another way to reference the vi?
04-22-2024 07:23 AM
Send out the VI's path in a one button dialog in the target VI. I'm assuming it now is similar to 'C:\temp\ActiveXpractice\My Application\Application.exe\library.lvlib:ActiveXPractice.vi'
04-30-2024 10:33 AM
Thanks for your response, I still couldn't get it to work though. I ended up going with UDP communication instead. The LabVIEW executable sent info to a UDP port and I was able to read it using Python.
05-01-2024 09:12 AM - edited 05-01-2024 09:15 AM
The reason is that if you have multiple VIs in different sub-directories, LabVIEW builds the path inside the executable relative to the project directory. So the path created is actually including intermediated directories relative to the directory the project file is in.
You can disable that by checking the checkbox in the Build Application Properties under Advanced->Use LabVIEW 8.x file layout. But that will not work if you have multiple libraries or classes with VIs that have the same name.
