Passing a Windows Form reference from C# .NET to LabVIEW
Well, in case that 2 processes are involved, the easy approach I described is not applicable indeed. Nevertheless there are more flexible ways to have different processes talk to each other than old-school Windows messages. One technique are so-called named pipes:
Fortunately, they became pretty handy with .NET 3.5:
Anyway, if your application works like it should, leave the implementation as it is. I'd just recommend having a look at named pipes forfuture uses.
Cheers,
Hans
P.S.: As long as no inconsistencies or exceptions occur, thread unsafe GUI updates are no issue. But when they come, you'll know whatto look for! 😉
Well, in case that 2 processes are involved, the easy approach I described is not applicable indeed. Nevertheless there are more flexible ways to have different processes talk to each other than old-school Windows messages. One simple technique are so-called named pipes:
http://msdn.microsoft.com/en-us/library/aa365590(VS.85).aspx
http://www.switchonthecode.com/tutorials/dotnet-35-adds-named-pipes-support
A different, much more powerful (and elaborate) way to transfer data between loosely coupled components is MSMQ:
http://msdn.microsoft.com/en-us/library/ms711472(VS.85).aspx
MSMQ is something that really rocks, I absolutely love it and I could cry about the fact that it's so little known.
Anyway, if your application works like it should, leave the implementation as it is. I'd just recommend having a look at named pipes and the like for future uses.
Cheers,
Hans
P.S.: As long as no inconsistencies or exceptions occur, thread unsafe GUI updates are no issue. But when they come, you'll know what to look for! 😉
Message 11 of 14
(1,282 Views)
BTW, regarding MSMQ: I've posted an example in the forum some time ago:
http://forums.ni.com/t5/LabVIEW/MSMQ-with-Labview/td-p/154334
Wow, 3 years ago. Time flies...
My very basic example uses polling to read messages from a queue frequently. In real world applications, you'd rather use event based message retrieval.
Message 12 of 14
(1,279 Views)
CAR 242214 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 13 of 14
(1,008 Views)
Thank you NI
Three years from report of the bug to a fix which isn't too bad considering it was a low priority request (with relatively few people benefiting from it).
regards
Peter Badcock
Product Development
ResMed Ltd.
Peter
Message 14 of 14
(1,000 Views)
