Performance of Property Nodes as class accessors
LV2013
I vaguely remember reading somewhere that property nodes require a LV context switch, because they must be run on the UI thread.
<ul>
<li>Is that still true?
<li>Is that true even if the node does not pertain to a user control (e.g., an accessor for a private data field in a class) ?
<li>How much of a penalty is that? Anybody ever measured it?
<li>It's convenient to use a property node with 2+ terminals to access 2+ fields.  Is that convenience outweighed by the performance drop?
<li>Are there papers or other docs explaining all this?
</ul>
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,391 Views)
Accepted by CoastalMaineBird
This is only true of property nodes that run in the UI thread, such as ones that refer to the front-panel elements. Executing a LVOOP accessor through a property node is just syntactic sugar around a standard VI call, and doesn't force a thread switch. I seem to recall reading that there's a slight difference in that read accessors will always execute sequentially due to error handling, but I can't find that post in a quick search.
(3,372 Views)
Thanks, nathand
So the rule is that UI property nodes must execute in the UI thread.
That makes more sense.
Steve Bird
Culverson.com
LinkedIn
(3,364 Views)
