01-22-2025 07:49 AM
Hi all
I am trying to plot data on waveform graph with 1MS/s. Same data size I have to plot for 6 graphs. When I try to write data to graph the code will be crashed and throw error like NOT ENOUGH MEMORY TO COMPLETE THIS OPERATION. Please suggest idea to solve this issue.
01-22-2025 08:35 AM
Hi duraik,
Don't plot so many samples on your graph(s)!
Decimate the data to a reasonable amount of samples. (Hint: number of plotted samples should be less than twice the graph width in pixels…)
01-23-2025 01:40 AM
Hi GerdW
Thanks for your reply. Actually, my requirement should not decimate the samples.
01-23-2025 01:52 AM
Hi duraik,
Then this requirements sounds silly!
IMHO it doesn't make sense to display a 1MS/s stream of data completely on a graph with ~500 pixels width…
