Printing 2d array in Table indicator
Hi, I am beginner in LabView. Please help me!
I have 3 values in event structure (triggered by a button press). I want to show them in a table indicator. Every time the event is triggered it should append in the table.
Table indictor wants 2d array and i am not able to make one without a loop.
(1,057 Views)
Hi the Table is a 2D array of string, you need to convert hte numbers to String . I used a Property node "Value" from Table control  to read the current 2d array and append the latest 1D array from the controls on your front panel and write back into the Table control
(1,011 Views)
  • Your table should be an indicator, not a control.
  • Just keep the table data in a shift register and update accordingly.
  • None of your local variables are needed.
  • Terminals of latch action booleans should be inside their respective event case
  • There is no need for a timeout event.
  • Your chart should be an xy graph.
(995 Views)
See if this can give you some ideas...
(989 Views)
