Problem on For-loop output to Cluster
Hi!  I am using Labview 2009.
I have a problem when forwarding the Indexed numbers from a for-loop via the array-to-cluster function to a cluster. Please check out my attachment... The problem is, it always says the number of elements in the Indexed numbers is 9, whatever number of loops I input for the loop.
Has this problem been solved before? I couldn't find any related post here..
Raymond
(2,695 Views)
Accepted by vgbraymond
Hi Vg,
You need to right click on your array to cluster function, goto 'Cluster Size' and select, in this case, 2.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(2,692 Views)
Lucither, thanks for your help! Labview is so user-friendly that I rarely need to take care of a size setting while putting control and indicator together, and I will take this as an exception 😃 Thanks so much!
(2,687 Views)
