12-07-2008 06:02 PM
I am trying to write data to a spreadsheet file and I believe I am going through the correct steps but am encountering a problem when I try to open to file. My filename has the extension .xlsx (Excel 2007) and I open the folder I've specified to creat the file in but when I try to open it it comes up with an error telling me that the file may be in the wrong format or have incorrect extension. I realize I can just write to a text file and open the text file with Excel but I've been trying to do it this way and just want to know if I am doing something wrong or if it is an issue with Excel. One helpful tidbit I should probably include is that I'm using LabVIEW 8.6.
Thank You,
bsteinma
12-07-2008 06:49 PM
12-07-2008 09:54 PM
Thank You Ravens Fan,
I haven't had a chance to try this yet but I will let you know if it works. I am using LabVIEW for a senior design project in biomedical engineering just for a little background and am pretty new but have enjoyed getting to know the program. I believe your solution will work and will let you know tomorrow if it worked.
Thanks Again,
bsteinma
12-08-2008 03:10 AM
12-08-2008 04:45 AM
Hi bsteinma,
Have you tried using "Write to Measurement" (Block Diagram>Programming>File I/O>Write to Measurement File)?
I am using this to record data and open in office 2007, no problems with it.
Please let me know how you get on
Chaz
12-08-2008 04:54 AM
Hi bsteinma,
you should define the wording "spreadsheet file" more exactly...
Are you writing a LabView spreadsheet file? Then you create a tsv (tab separated values) file. If you give it the extension ".txt" (or .dat, or .csv) Excel will open/import it correctly...
12-09-2008 09:05 PM
Thanks everyons for the help and input. Most of the proposed solutions worked in one way or another. I may revert to creating a text file and then just opening it with Excel.
Thanks Again,
bsteinma
