Problem running VIs in EXE
Although the example provided here ( TopLevel MOD.vi ) works perfectly.
Unfortunately when I applied that in my real application it failed to work.
I've been very carefull to check the properties of the project but to with no luck.
What I've done instead is in orer not to build the path I used a Static VI reference node.
This work the same in the Development System and the Runtime system.
... I do not understand why this still fails to work for me in my real world app ... but ... I have to move on.
Thank you all for the help and input.
Maciej
Message 11 of 14
(539 Views)
Interesting, I couldn't get that to work on LV7.0.  Maybe that functionallity is not available on it.  😞  Could you provide a pic?
Thanks.
A
Message 12 of 14
(528 Views)
That's because LV 7 does not use the same file structure as 8.x, or even 8.5+, as I mentioned.
Message 13 of 14
(524 Views)
Sorry, wasn't referring to the file hierarchy.  I was refering to the static vi node.
A
Message 14 of 14
(521 Views)
