Problems with Tangent
Hi! I have a problem, I want to calculate tan(90), but my program shows as result 1.63x10^16 and that's impossible, I don't know what's wrong, how can I fix it? Thank you in advance for the advice 🙂
P.S. I leave you a picture of my VI
(3,382 Views)
You aren't calculating the tangent of 90 degrees, you are calculating the tangent of some number of radians. The tangent doesn't know about units, only values.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,372 Views)
@Boramina wrote:
[...] my program shows as result 1.63x10^16 [...]
Tan (90 degrees) = Opposite/Adjacent = 1/0
 https://www.google.com/search?q=Tan+(90+degrees)
Jim
(3,311 Views)
Accepted by Boramina
The tangent of 90° is infinite.  When LabVIEW attempts to compute it (probably through a series approximation), rounding errors creep in and you get a Very Large Integer, instead.  Look at the picture of the Tangent function -- see it approaching infinity at 90° (from the left) and rising from minus infinity as it crosses 90°?
(3,251 Views)
Well, you get the tan of a number that is very, very close to 90 degrees. Ideally you should get +inf. floating point operations involving fractional values are almost never exact.
If you take the arctan of +Inf, you get Pi/2, though.
Please explain what you mean by "impossible". We are dealing with numerical methods, not with symbolic math here.
(3,234 Views)
