Processing data in labview
i want to implement two types of data sets: one is the lock in output voltage and the position of the delay stage with wait time, i want to synchronize these two data sets, can any one help me how to start this as i am very new to this soft ware, learning it as a intern student. i have created two codes, one is for delay stage and another is for lock in amplifier output voltage measurement. we have both this set ups in our lab.
Message 11 of 16
(221 Views)
@Lily3000 wrote:
i would check if the rise time of second signal -+10% of the rise time of the first signal. How I can do this is Labview? so far, i mostly did data acquisition in labview and data processing in python
So how did you do it in Python? You should be able to port the algorithm 1:1.
So you have two signal recordings, both with the same start time (because the fist points overlap) and both show a dominant frequency that is the same. So you are apparently looking at a phase difference and a ±10% would be about ±36 degrees, and there are many ways to get that. Once you attach a VI containing some typical data, we can try a few things.. Since the signal is periodic, there will be many more solutions 360 degrees apart.
Do you know the main frequency exactly?
Message 12 of 16
(202 Views)
I do not have any VI's because signal comes from scope, ill try to make one and upload here, thanks a lot
Message 13 of 16
(197 Views)
We need both signals. but you could attach the as a tab delimited text file, for example. What do the signals represent? Again, do you know the dominant frequency exactly?
Message 14 of 16
(190 Views)
The signals are current and motor speed (as square wave)
Message 15 of 16
(149 Views)
I suppose you can just measure the frequency and phase of both signals and compare them. If both are within your 10% tolerence, you can output True. Try the "Extract Tone" vi.
Message 16 of 16
(134 Views)
