Producer/Consumer vs Master/Slave Data loss
Hello Labview users,
I have been experimenting with P/C vs M/S lately in the context of data aquistion. Lots of posts have made it sound (Correct me if I'm wrong) that P/C is the correct architecture to if data preservation is desired, so that's what I've tried to implement.
In the producer loop, I've included 3 DAQ assitant VIs (2AO, 1 AI), one that actively generates data and is being enqueued. I have 3 other consumer loops, two of which are consumer loops 1) Writes data to TDMS 2) Outputs to a graph 3) Non producer: Event structure, monitors changes to UI.
When I run data aquisition, the file generated are consistently half i.e. aquire half the number of sample that  I have specified regardless of the sampling rate. I also have a weird graph being displayed (See attached image).
However,
When I replace the architecture with a Master/Slave, this seems to solve the whole problem.
Question therefore is: has anyone come across such problems? Are there any downsides to sticking with M/S as opposed to P/C in terms of data loss?
(3,748 Views)
Can you please elaborate more on what you have differently between your Producer/Consumer and Master/Slave code? Producer/Consumer is a subset of Master/Slave and so dominant these days that I don't hear the term Master/Slave used much anymore.
If you're losing data then there's something you must be doing wrong. Please include a Snippet of your code, or attach your VIs, so that we can better assist you.
Cheers
(3,722 Views)
From the picture you have attached, you only have one queue.
Do you have multiple loops that are dequeueing from the same queue? That is a no go!
You need to have a queue for every consumer that you have.
(3,706 Views)
Didn't know you could do a snippet. Here goes. I believe that I am properly dequeueing
(3,675 Views)
Accepted by topic author johnji
You are not.  Once an item is dequeued, it is gone.  Since you have three loops dequeueing from the same queue, each loop will get ~1/3 of the data.  If all of the loops are to process everything, then you will want a different queue for each loop and have the producer write to each queue.  Alternatively, you could use an User Event.
GCentral
(3,658 Views)
Back to the original question.
The main difference between Master/Slave and Producer/Consumer is that M/S using a Notifier while a P/C uses a queue.
A Notifier is a broadcast message, so everybody can get it.  However, you can miss a notification if your loop is slow.  The Notifier is lossy.  You overwrite a notification each time you write to the notifier.
A Queue is a lossless FIFO.  It is meant to only be read from 1 consumer.
So if you truely want no data loss, then you need to use a queue.  But since you are trying to have many loops dequeue the data, you really need a different queue for each consumer loop.
GCentral
(3,650 Views)
To expand on Cross' text: Queues are a Many-to-one relationship, Events are One-to-many. If you want to signal many loops you should use an Event driven producer/consumer, or use individual queues for the relationship reasons just stated.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,610 Views)
