Profinet interface using the Hilscher CIFX 70E or CIFX 50E boards
Does anyone have any experience using the Hilscher profinet with LabView.  The Kunbus option is not available in PCIe and I need to communicate through that interface.
Message 1 of 11
(5,823 Views)
Accepted by stevegraff
Hi Steve,
I do not have experience with this combination, but a quick search brought me to this page: http://www.xon.de/en/project_industrial_ethernet.html
In step 4, it looks like they're calling into the driver DLL to communicate over Profinet. So, it looks like it might be possible.
It might be worth contacting XOn Software if there isn't more info that comes up on this forum
P.S. Also found this post by "Mads" on lavag.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
Message 2 of 11
(5,815 Views)
Looks easy enough.  I'll give it a try when the board comes in.
Message 3 of 11
(5,795 Views)
I also have problem, with handle, the CIFX 50E driver handling in Labview, because for windows 10 driver has changed
significant. I dont know, hogy should i handle pointers, C typedefed structures, values of structures. I dont know, how
sould i read the values of conllex variable (wich defined in dll) if i only have returned pointer in Labview.
I found worhking examples for the old Cif32dll.dll, but for windows 10 the had write the new cifX32DLL.dll (significant
changes).
Should you give me any help, or any example?
I sent all information, driver, documentation, and other material. (CIFX.ZIP)
Message 4 of 11
(5,137 Views)
Meanwhile the PCIe Version of the KUNBUS DF PROFINET IO board is available and can be ordered at Kunbus (https://www.kunbus.com/pc-cards-profinet-io.html)
Message 5 of 11
(4,771 Views)
Did you got solution. I am facing issues with cifx re 80.
Message 6 of 11
(2,602 Views)
Kunbus has stopped manufacturing the PXI card for profinet. Do you have any solution for same.
Message 7 of 11
(2,570 Views)
Did you got any solution. I am facing same issue with Profinet Cifx
Message 8 of 11
(2,569 Views)
I have a problem with the Hilscher device, too. The program runs from the IDE but not when I compile it to an EXE.
Does anyone have a solution on this problem?
Thank you!
Message 9 of 11
(1,792 Views)
According to our experience there is no difference between cifX access in IDE and EXE respecitvely. Did you have a look at Hilscher Knowledge Base? There is an example available at
https://kb.hilscher.com/pages/viewpage.action?pageId=108958342#cifXandnetHOSTintegrationinLabView[DE...
If this doesn't help we could build the interface for you as we have a vast experience is that field - see https://www.hilscher.com/solutions/success-stories/success-story-pc-based-automation-with-unified-in....
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
Message 10 of 11
(1,742 Views)
