Programing 6221 keithley conected to 2182a(as master)
I do need help
Im just started learning labview
I dont know how to connect and program 6221
I connected the device(6221 connected to 2182a) via rs232
Can anybody explain step by step what should i do
I searched a lot but couldnt find any thing
for your information again
I havent download any drive or anything
Message 1 of 8
(244 Views)
If you are referring to NI USB-6221, it is a DAQ device and doesn't support RS-232 natively.
You can buy an off-the-shelf USB-to-RS232 converter and run Keithley 2182A Nanovoltmeter - Instrument Driver
Control Lead | Intelline Inc
Message 2 of 8
(210 Views)
Sorry, there was a mistake in my question that I realized now
two devices connected with rs 232
I wanted to program through digital io that i used rs232 to usb cable to connect my laptop
Message 3 of 8
(186 Views)
Hi amir,
Could you please reword this sentence?
  • Which device is connected to your computer?
  • Which kind of cable (aka communication bus) is used for each device?
  • How does the "digital IO" come into play when talking about RS232 communication?
Message 4 of 8
(179 Views)
  • 6221 is connected to my computer
  • to devices(6221 and 2182) connected by rs 232 and trigger link
  • I said , i made mistake in my question . I connected 6221 to my computer from digital I/O port
Message 5 of 8
(175 Views)
Hi Amir,
We do talk about the USB6221 from NI? Or do we talk about the Keithley6221?
I guess you talk about two Keithley devices (6221 and 2182): How exactly did you connect the Keithley6221 to your computer? One bullet point says "RS232", the other says "digital IO port"…
Message 6 of 8
(165 Views)
I meant keithley 6221
Let me say it like this
Forget rs 232
I connected the digital I/O to laptop usb with a cable
Message 7 of 8
(160 Views)
Hi Amir,
@amirfh wrote:
Forget rs 232
You need to explain this with more details!
  • Which digital IO did you use?
  • Why (and how) did you connect those "digital IO" to the USB port of your computer???
  • What do you want to achieve with this connection "to USB"?
Message 8 of 8
(149 Views)
