Property Nodes/Features for Charts
Hi everyone,
In my program, I have a chart which can have up to 40 plots on it.  I have a feeling this isn't a feature, but a colleague of mine asked if it is, so I thought I would ask anyway.  Is it possible to hover the mouse over one of the plots on the chart and have it tell you what plot it is?  I have a legend for the chart, but with up to 40 plots, it can be difficult to read.
Thanks!
Message 1 of 12
(4,944 Views)
We don't get that function, but this might help.
Right Click on your Plot Legend and select Visible Items, then turn on the Plot Visibility Checkbox.
This will allow you to turn plots on and off to clean things up a bit.
=== Engineer Ambiguously ===
Message 2 of 12
(4,912 Views)
You can use cursors to do this.  There is an XYGraph.Cursor.Plot property node.  Note however that I have never had good luck with cursors... they often exhibit unexpected behavior.
Basically you will trigger on the XY Graph "Mouse Down?" event.  Look at the coords, call the "Map Coords to XY" invoke node. then set the XYGraph.Cursor.PosX to the X click.  It should snap to the nearest plot and then the XYGraph.Cursor.Plot will tell you which one the click was closest to.  (You could of course do this with the Mouse Move event to get a constant udpate and have hidden cursrors).
Message 3 of 12
(4,910 Views)
Here is some sample code
Message 4 of 12
(4,898 Views)
Cursors don't work on charts, AFAIK.  The OPs post was for charts.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 5 of 12
(4,896 Views)
Oops!  I missed that he wanted it on a chart.  Thanks:)
I have done an XYGraph with a circular buffer before so it behaved like a waveform chart but that gets cumbersome.
Message 6 of 12
(4,893 Views)
Accepted by _natalie_
Yes
The above may be a start.
It is messy but ssems to work.
Ben
Message 7 of 12
(4,806 Views)
Hmmm...
Nobody wanted to call me out on using the X value as the sample array index huh?
(smiley-wink)
Ben
Message 8 of 12
(4,782 Views)
@Ben wrote:
Hmmm...
(smiley-wink)
Ben
I wanted to... until I ran your snippet to see what you were doing 🙂  Clever solution.
Message 9 of 12
(4,775 Views)
Well, I thought about a similar solution but what happens if you have two plots in the same location?  I couldn't think of a way to handle that so I didn't even try.  Smiley Frustrated
Maybe your solution does handle it???  Nice job.
aputman
Message 10 of 12
(4,760 Views)
