PtByPt; Derivative issue
I'm working on a program that continously read data from serial port (FS =1000). I have chosen to read the data in blocks of 512 in producer loop and send it via FIFO to the consumer loop. At the consumer loop I would like to filter and get derivate the signal.  I wrote a simple program to illustrate my problem, the program simply produce a sine wave of 128 point per cycle and i filter that wave with a band pass filter (assuming a FS of 1280 Hz). That works fine! What I dont understand is the derivative part and the meaning of dt. I expect it should be 1/1280 but this givs a wronge answear. I saw a solution in which they take the difference between Xn-1 and X0 of the signal block and insert it in dt Smiley Frustrated If I read the description in the derivtive the meaning of dt is sampling interval and it should not be equal or less than zero. So what have I missed???Smiley Mad
(3,553 Views)
This looks correct to me.  A few things I did:
1. Set the Initial Condition to the first data point
2. Removed the First Call since that is done inside of the VI anyways.
3. Set the dt to be 1/1280.
GCentral
(3,539 Views)
Thank you crossrulz!
I started with your suggestion what I get it is a derivative that is 63,8 time higher Smiley Surprised
(3,527 Views)
Accepted by ahmalk71
ahmalk71 wrote:  I started with your suggestion what I get it is a derivative that is 63,8 time higher Smiley Surprised
If you go through the math, that is correct.
d(sin(2*pi*128x)/dt = 2*pi*128*cos(2*pi*128x)/dt.  With dt = 1/1280 you end up with 20*pi*cos(2*pi*128x).  20*pi = ~63.8
GCentral
(3,495 Views)
DarnSmiley Mad I forgot about the internal derivativeSmiley Embarassed
ThanksSmiley Happy
(3,486 Views)
