Quick Load a Tree?
I have a dialog box that presents a tree with a lot of items.  The tree is loaded from a file* and the load time is a bit annoying.
For normal calls, I have it load the tree on the first call only.  But there are some calls that reload the VI every time ** so each call is a "first call".  This results in the dialog VI reloading the tree each time.
Is there any trick to quick-load a tree?
* A file that almost never changes
** And that's beyond my control
Message 1 of 9
(1,677 Views)
Accepted by paul_cardinale
Are you turning on "Defer panel updates" when you add the nodes to the tree?
If I add 1000 items to a tree un-deferred, it takes ~2.6 seconds.
If it is deferred, it takes 0.1-0.2 seconds.
Message 2 of 9
(1,654 Views)
If you haven't already, use Defer Panel Updates
Message 3 of 9
(1,649 Views)
I have struggled with fast tree based file browsing of a remote machine. I ended up indexing the file system of the remote in the background and creating an XML file with the entire file system represented in XML maybe similar to your file*. The file browser tree UI object is a singleton that only exists in a popup VI on the local machine that is running but hidden so it can load the tree in the background. When the user gets around to opening the file browser it is already loaded and ready to go browse.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 4 of 9
(1,640 Views)
Gee, I knew that; but I'm getting more forgetful in my old age.
Message 5 of 9
(1,601 Views)
The main problem with trees (and IIRC enum, ring and combobox items) is the time it takes to add items is exponential growing with the number of items. Even with defer panel updates on (or the tree hidden).
There's a tree method to add bulk elements. But it's limited and, in my experience, it isn't much faster and if it takes long, it hangs LV until it's done.
What can help is 'lazy visualization': only show parent items with a dummy child if they have 1> children. Then populate the children (again with dummy child) when the user expands the parent... Not trivial to implement, and it only helps for non-shallow trees. And obviously it only works if the initial view has all items closed.
Message 6 of 9
(1,539 Views)
I had to test, and a .NET tree view in "batch" mode is quite fast!
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(1,454 Views)
And it scales up much better.
LV seems to check each added item against all existing items (to create a unique tag I assume)... This gets old (or slow) fast.
Even 20000 parents with 2 childs is reasonably fast (few seconds). LV will take much longer (6 seconds), and after adding the items the FP is non-responsive for much, much longer (2 minutes 😑)...
Message 8 of 9
(1,445 Views)
I tried 1000 mains with 50 childs each and it was 1.67 secs on my laptop. 🙂
Qestit Systems
Message 9 of 9
(1,416 Views)
