Quitting remote front panels messes up program
I have successfully connected to another computer running my VI using remote front panels. The computer running my VI is using parallels on a mac. When I connect to the VI I am using safari on a mac. Whenever I want to exit the browser I press Quit and it shuts down, but sometimes this messes up the program and I get an error. The error occurs when I try to write to a property node of a boolean LED. Is there any way to prevent this from happeing? I have attached pictures of the error and the spot where it happens.
(2,772 Views)
Accepted by MaddieDrake
Disable automatic error handling in the VI properties, or put a Clear Errors VI (from the dialog palette) after the property node.
Property nodes only work when there is a front panel available. When you disconnect the remote front panel, the VI no longer has a front panel available, so property nodes generate errors. You need to ignore that error. If your code relies on reading and writing property nodes - if the logic won't work properly without them - then you need to restructure your code. When no front panel is connected, the Value (Signaling) property will never generate an event.
(2,755 Views)
