RPM Measurment
which module can be used in cDAQ system for measurement of the RPM of the Motor???????
Message 1 of 12
(4,184 Views)
Hi umer,
why don't you call your local NI sales rep?
Please collect other needed specs before doing so! (Like: voltage levels, pulse speeds, etc.)
General answer: any DI module supporting counters…
Message 2 of 12
(4,158 Views)
can you name some modules that support Encoders
Message 3 of 12
(4,123 Views)
Hi umer,
this one is listed as "counter module", but please call your local NI sales rep to discuss other options!
Message 4 of 12
(4,120 Views)
yes i would definitely contact , but does this measure 10000 RPM?
Message 5 of 12
(4,117 Views)
Hi umer,
the NI9361 supports upto 1MHz at its inputs!
You need to calculate your pulse rate from specified max rpm and the number of pulses you need to count per revolution…
Example: at 10000rpm and 360ppr (pulse per revolution, typical value for encoders) you need to count pulses at 3600000, so this would be too much for this module. But when you use an encoder with just 60ppr it will be fine!
Again: collect all your specs before calling the sales guy!
Message 6 of 12
(4,108 Views)
Thank so very much
one more thing, can you tell me the temperature module required to measure 15000 degree celsius using thermocouple i have a CDAQ-9147
or should i use RTD setup,if yes please suggest the module i require
Message 7 of 12
(4,090 Views)
@umer777 wrote: ...required to measure 15000 degree celsius...
Care to try that again?  You are talking about hotter than the sun (5,778 Kelvin).
GCentral
Message 8 of 12
(4,087 Views)
Oops... It's 1500 degree Celsius
Message 9 of 12
(4,080 Views)
Hi umer,
to measure temperatures of upto 1500°C you can use thermocouples.
Pick a suitable type (type S is quite common), then check for a suitable DAQ module (like NI9213).
Call your local sales rep to suggest a module!
Message 10 of 12
(4,070 Views)
