Random Number w/ Min/Max, Min stays at zero - not taking the random #s
My issue is that the minimum is staying at zero, how can I get the minimum to output the first random # and then compare from there?
(472 Views)
Accepted by topic author Anomalous
You need to initialize your shift registers.
Typically, the min with +inf and the max with -inf.
Else it remembers the last values between runs. On the first run, you get the default, i.e zero, which remains the min.
(456 Views)
Also remember that we have ptbypt VIs, so your code look as follows:
(Depending on the rest of the code, you might what to init if i=0)
Also note that your loop time is instantaneous, so the indicator terminals don't belong inside the loop.
(398 Views)
