Random unit vector (x0, y0, z0) generating
Does exist function that generates random unit vector 3D (x0, y0, z0)
Thanks in advance
Pavel
Message 1 of 26
(5,225 Views)
Generate random 3D vector and use the Vector Norm function.
Ben64
Message 2 of 26
(5,205 Views)
It is called a FOR loop.
GCentral
Message 3 of 26
(5,203 Views)
Hi Pavel_47,
How about that?
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 4 of 26
(5,183 Views)
Hi Sabri,
A unit vector has the property that the sum of the squares is equal to 1. Yours will have the sum anywhere from 0 to 300.
Message 5 of 26
(5,170 Views)
Didn' new. Thx for the info.
Message 6 of 26
(5,145 Views)
Knew 🙂
Message 7 of 26
(5,143 Views)
Just realized that using random number (0-1) will only generate a unit vector in the x+,y+,z+ region of the 3D x,y,z space. Here is a modified version to correct that. This is a quick fix there is probably a more elegant solution (maybe using complex number).
Ben64
Message 8 of 26
(5,115 Views)
Accepted by Pavel_47
Well ... I've searched a little bit more and found approach base on polar coordinates: only 2 random variables are generated and they are completely independent.
Here it is.
Pavel
Message 9 of 26
(5,089 Views)
Hi Pavel,
I think parameterizing in spherical coordinates is a good way to go. You do still have 3 variables to describe a 3D point in space of course
Spoiler
you've just set |r|=1  Smiley Happy
Message 10 of 26
(5,020 Views)
