Raw Ethernet Packet
Dear sir,
We are trying to establish communication between FPGA board and PC. Here FPGA transmits the data which is in raw Ethernet frame format. Now PC should receive the same data without filtering like
DD DD DD DD SS SS SS SS TP <data> where “DD” is the Destination Address, ”SS” is the Source Address and “TP” is the type of Protocol.
Kindly let me know the implementation procedure for the above mentioned issue in LabVIEW.
Thanks & Regards,
S Nagaraju
(3,429 Views)
Use a FIFO to transmit the bytes of data of the packet to the PC and then decode them. For efficiency I think you can combine the bytes into U32s and unpack them on the PC side (I think FIFOs transmit 32-bytes of data even if you select a smaller data type). You may want to add some sort of header to the message so you can find the start/end of each received packet on the PC side.
(blog)
(3,420 Views)
LabVIEW has no APIs for dealing with raw Ethernet. All of the relevant APIs are wrappers for implementation of higher level protocols. If you really want to handle the Ethernet data directly, I think you can use WinPcap, and there should be some wrappers for it if you search here, but I have no experience with it.
___________________
Try to take over the world!
(3,348 Views)
